av9000 and beolink active question
hi,
hopefully someone can help.
i have connected a beolink active (with eye) to my av9000 (which is running as a slave off the master avant) so that i can control my sky+ box on the avant (can't be done directly with the av9000), but to get it to work i have to put the tv onto say channel 6, then on the beolink controller i need to find 'link' & go > then 'sat' which then allows me to change channels, however if i then want to say turn the volume down i have to go back to 'tv' and then go back through the process above after - is there a way that i can program a l-sat option or something so that the process can be simpified?
thanks in advance
steve
You can use a Beolink 1000. This remote is able to change AV9000 volume even it is in LINK SAT mode, and it has a specific button for "LINK".
You can also use a Lintronic box. This box could send "TV - 6" IR macro command, when receiving -for example- LINK - SAT. So you could activate your AV9000 AND  Avant by pressing just LINK - SAT.
Hope that helps.
Stefan
er, I use my Sky + directly off of my AV9000.............
What's stopping you do that?
Cheers
GUY
thanks stefan/guy.
will look at getting a beolink 1000 and giving that a try first.
cheers
steve
My AV9000 also has a Sky box attached - however I am aware that the STB-C module is no longer easily available. I didn't think the AV9000 could be used as a slave though! 😂 Which model is it?
sorry, what i meant to say was, i have an av9000 which i can't run as a slave off the master avant!
steve
