Dylan,
Putting aside price, in my view, you should not consider buying a BeoVision 7 in the UK and trying to use it in Australia unless you find you can buy a Australian version from a UK dealer which I expect is unlikely.
Taking the BeoVision 7-32 as an example
The 7-32 in the UK is type number 9334 and in Australia it is type number 9335
The differences are:-
| TV System | Sound Offset | DVD Region | Stereo |
| Australia | PAL B & G | +5.5 Mhz | 4 | FM-FM |
| UK | PAL I | +6.0 Mhz | 2 | NICAM |
The first thing you would notice if you tried a UK set in Australia is that you would not get any sound.
Now having said all of the above, some things can be changed using the service menu, but you need to know what you are doing, for example on most B&O BeoVision units these days you can change between the various PAL types which (may ?) also change the sound sub-carrier, either way you are going to need the help of your friendly B&O dealer which is likely to be chargable because the Australian B&O dealer did not make a margin on the product sale.
So, if you purchase one in the UK you still have the shipping cost and any possible shipping damage to consider before you get to watch you BeoVision in Australia.
Keith..
