Hi Guys,
I'm really curious if you will be able to solve this, PeterG, since I would like to make a similar configuration, but with BV3 or AV9000 also using the scart input.
Today I have a Apple TV ver.1 connected to my BV3 using ATVFlash software to convert the video signal from component to composite so I can connect it directly to the Scart.
The result is brilliant colours and sharp ( as sharp as can be on a BV3 with 480i resolution) Before I got this soultion I tried 4 different converter boxes and all resulted in a blurry picture that would just annoy me if watching a whole movie.
Now, since the release of the ATV 2 ( Black) there is no possiblity to convert the signal with software since its HDMI, so a converter box will be your only option. However, those converters mentioned in this thread, is only converting from one digital to another digital interface, so I frankly don't think that will work (correct me if I am wrong...and I really hope I am wrong here :- ) since I want a ATV2 for my bedroom AV9000)
It seems like those converters can convert from HDMI to Component, but not Composite, right? And that will not work..in best case you will get only black and white picture..
If somebody gets an ATV2 to work on a analog CRT TV, please post..and I mean, working with a picture quality that really crisp and nice and meets the B&O level we all want....
/Peter
