Atlona HDMI Matrix, BV11, V1
Check that both mini cables going to the IR on the baluns are identical. The Matrix is very sensitive to different mini cables.
OK, check that - Both cables are identical (white with a bulge in the middle), same markings etc. I have swapped them between the two TV's and the behaviour remains the same (one TV works, the other doesn't - I cycle the power on the switch and begin with the previously non working TV and it is fine but the other one now has the problem).
I.e. I can recreate the symptoms on demand and both sets have same issue if the other set was used before (after a power cycle). It's as if the first set being used 'takes over' the switch and the 2nd set can send whatever commands it desires it has no impact whatsoever (until a restart). That said, the IR relay to sources works perfectly so i can conclusively proof that the BV is sending PUC commands and that those commands are being relayed - It's only the matrix switch that selectively responds (or not) to PUC commands intended for it.
