I have a concern about the AR coating on the contrast glass of my BV10. Here's what happened:
I used an Eye1 sensor to calibrate the color profile of my Mac, which uses the Beovision as its screen. Using the sensor, I made a smudge on the contrast glass. I thought it would be safe to remove it with OptiClean, a cleaning fluid suitable for even delicate camera lenses and coated eyeglasses.
Well, the OptiClean left some residue on the contrast screen. So I took a soft cloth, dampened with water, to remove it. As it happens, even water leaves streaks on the glass, so I had to work with a damp and dry cloth to get a perfect, shiny result with no visible marks or streaks on the screen.
But in doing this, is it possible that I damaged the AR coating? How easily is the coating damaged? How can I see if the coating has been "worn off"? Has anyone seen a damaged AR coating and what it looks like?
I am very careful with my equipment and keep everything in perfect condition. So the idea of a damaged AR coating bothers me -- to the extent that I asked my dealer for the price of a replacement glass, but since a new front glass for BV10 comes assembled with the aluminum frame, a replacement costs about 1900 euros.
To my eyes, the cleaned screen reflects light somehow differently than before cleaning, but I may as well be seeing faults where there are none. That can happen when you start looking for imperfections in the first place :(
Does anyone have experience / information on the durability of the AR coating?
