The Android app has just been updated, but no real word on what has changed.
April release of the Bang & Olufsen app
@ThatGuyFromDenmark: This was a hotfix release fixing crashes observed in our logging and TuneIn metadata from Moment. We usually do not update the release notes for hotfixes
Yes correct, so i would use AirPlay to send an Apple Music stream to zone 1. If I then wanted to join Z1 with Z2 using the bang & olufsen app this stops the music in Z1. I even went to Apple Music to press play however it stays mute until I close the bang olufsen app at which point I can't press play.I should mention, if I follow the same procedure but join using the Essence remote then I can enjoy Airplay in both Z1 & 2This has been tried on home and showroom system.@djfairley89: When you say apple music stream is that airplay? @mbolo01: I will check the Spotify settings
Worked. Thanks!-h.About the unreachable Moment, could you try to remove it from your account and re-add it?
Love the lockscreen feature. Very convenient 🙂 Display the Deezer cover art nicely.🙂
Login to view image
I agree, if I could get the same on the Moment it would be great!
Yann.
Hi
I'm using the app on my iPad and the play/pause button is not shown. However, when I press in that empty space it is still work. My android phone doesn't has this issue though.
Koblap
And the overlapping of the volume wheel and the player icon/name is an issue too.
I guess that we will have to wait for a proper tablet/iPad release of the app to solve these problems.
@MrAndersen
Are you sure that most of the app users are using their phone for controlling their B&O network?
Why wait with launching a tablet version?
+1 (Android & iOS)Why wait with launching a tablet version?
Regarding the iPad version. We're working on the dedicated iPad version but it still a couple of months away, sorry. It is not just a simple port of the code, some views will change and everything needs to work in landscape as well. This takes time to do.
Regading the broken UI on iPads for the current version. This is just a scaled version of the phone app and will not work completely. What we really wanted was to prevent you from installing on iPads before we were ready, but that is not possible. I'm afraid we're not going to spend time on fixing the scaled version, but instead spend our time doing the dedicated version.
