Apple TV+SkyHD+XBox 360 connected to BV7-32, HOW?
Hi all,
  Anyone else done this or is it not possible???
  BeoVision 7-32 MK3 connected to :-
1 I have the SkyHD going into DVI-I with scart for audio.
2 XBox 360 into component with red and white for audio.
3 Apple TV has nowhere to go??? Or is there a solutuion?
 Thanks in advance
Jonnie
I have my ATV from composite to scart (decoder) on my 4-42. Works perfectly and also did make ATV learn a remote that was included in my Set Top box. Now it is hidden in the cabinet and controlled by Beo4!
Hi, The best way is to look for a cheap Gefen HDMI expander on ebay which you can connect to the DVI & control with 1 of the STB controllers connecting up to four HDMI sources.
Regards Douglas
I don't think a non-HDMI BV7 will control an HDMI expander.
It is a possible solution if you want to control it manually.  Though you'll also need something to switch the audio too.
Thanks guys!
Not looking too promising then?
  Jonnie
Hi Jonnie,
Give it a try as I wrote. It should work. It does work for me with excellent results!
Best regards
Spiros
Hi, If you have an up to date STB list in your TV & the latest software 30,03 then you can operate a HDMI expander!
I know because i have it, I dont know if you can be bothered with the hastle & expense wiht this option as B&O must update Chip & Flash software!
Regards Douglas C
Hi Spiros,
  Maybe I am being a bit stupid 😳
  The only connection on ATV2 is a HDMI socket.
  Kind regards
    Jonnie
Ouppps. Sorry. I was talking about Atv1!!
No worries, thanks for the inputπŸ™‚
  Kind regards
    Jonnie
