Apple TV PUC
yes same puc as the old apple tv because the remote commands are the same
Or, just use any old device that is in your PUC table, and let Apple TV learn the codes same as you would teach it to work off a third party remote
I wish they would fix the multiple press of the go button for the genius menu as the fixed it for fast scrolling up and down
write them (B&O) a letter - they may not have realised it was a problem (I did not know it was !)
Hi there I told them years ago about it but they said they will look at it but that was that.
You won't believe how stupid you make me feel 😳
I have had my ATV2 for over 6 months, and I am to cheap to pay my B&O dealer to update the PUC list in my BV9. I know that the ATV2 is able to learn codes, yet I have never thought about this possiblity.
Thank you so much, now I know what I need to try out tomorrow 😁
Well I couldn't wait until tomorrow 🙂
I found a Samsung BD-Player/HD-Recorder, the previous owner of my TV had installed, and I can now control my ATV from my Beo4. Awesome 🤒
