Apple TV 4, 4K; and Beovision 14
Hi
I'm using the latest PUC the ATV 4 from IOS 13, however when i turn off the TV the Apple TV doesn't.
I have tried the > LIST > power function but that doesn't work
So i have to click > Settings> Power off the Apple TV then press the power button on the BeoRemote One to turn it off.
Does anyone else have a solution?
I have tried long press of each of the coloured buttons to see if the menus that come up with the Apple TV remote, but to no luck
Are there any other short cuts?
in the connections menu, when you set up and choose the PUC, my older TV has 4 choices
Off at source change
Off at TV standby
Always on
Manual control
Not sure if your TV has those options.
Stoobie
Exeter,
Devon,
UK
Thanks for your reply, I believe I chose
Off at standby
As that is the default one i always pick
Why not just set the ATV to go to sleep after 15 minutes.
Or alternatively why not the PUC turn off the ATV?
I don't think there is an option to turn off the ATV after 15 mins, it's later than that.  It's in a bedroom and the light is annoying.
Hello,
Choose the “manual” setting for a reliable result. Best of a bad bunch.
Cheers Beoaus.
Thanks beoaus
I have it set to turn itself off after some number of hours. It can’t be too short or it turns itself off if you pause a show and walk away for longer than you expected. Plus, the screen savers are quite nice.
cheers
