Frederik wrote:
Hi Geoff,
Thank you very much for you response, I am looking forward to your blog post!
Also a word of appreciation for your blog in general, you provide some excellent material. I regularly refer my students to some of your articles.
All the best,
Frederik
Hi Frederik,
Firstly, thanks for the kind words!
Don't expect the blog posting to come soon. It's no earlier than fourth in the list after
- an article explaining Jurin's Law and capillary action, and how it applies to fountain pen feed design
- an explanation of variable reluctance pickups for the section on the MMC cartridge in the Beogram 4000c manual
- a description of the straight line engine turning attachment I'm making for my wood lathe...
However, here's a quick outline for the "high sampling rate" series of issues-to-be-discussed (in no particular order...)
- an explanation of the Nyquis / Shannon theorem, confined to the simplest case of an ADC -> DAC
- including an intuitive example with a piano. Doubling the sampling rate is equivalent to adding one more octave on the top. There are as many "frequencies" in that top octave as there are in all of the other octaves below. That's logarithms for ya...
- aliasing
- an explanation of how any distortion in the signal processing creates aliasing "inside" the signal path
- quantisation of poles and zeros in the Z-plane, resulting in inaccurate filter behaviour at low frequencies - a "victim" of the sampling rate and the bit depth of the filter coefficients
- inaccuracies in filters' magnitude and phase responses above about Fs/4 (or Nyquist/2) as a result of the bilinear transform
- possible effects on the noise floor caused by changes in sampling rate - particularly in systems with a Delta-Sigma conversion between the analogue and LPCM worlds
- artefacts caused by poor (and sadly, ubiquitous) sampling rate convertors in the signal path
- possible side effects in systems with frequency-domain processing
- The basic stuff like bandwidth, block sizes, carbon-equivalent footprint of streaming data
- The ease with which labels can cheat, delivering 44.1/16 recordings in larger container formats just to look bigger than reality
- Warnings and pitfalls associated with doing A/B comparisons
There might be some more things to discuss that I'll think of when I get going on it. *However, as you can see there (and as I mentioned earlier in the thread) "I can't hear above xx kHz" is just one portion of that first point in a rather long list of issues to consider...
But first: capillary action!
Cheers
-geoff
