App BeoRemote vs. BeoLink
Hi I have two BV 11 with various other devices, also an MLGW and ML / NL converter in use. The BV11-46 I have configured WITHOUT power saving function The BV11-40 I have configured WITH power saving function. With the App BeoLink I can control all my B&O devices, also I have some macros that work perfectly. In addition, the home system is connected and integrated in BeoLink App, everything works perfectly.But, If the BV11-40 was put into a power saving mode, I can it not turn on with the app BeoLink. With the app BeoRemote can I turn on him at any time (but I do not like this App, even I can't control the house system) Can you give me a hint what I have to do for using the BeoLink app also when BV 11 is in power saving mode? The corresponding BV configuration I have already made, otherwise the BeoRemote via Wake on LAN would not work. Thanks and regards, Hermann
Take it out of power saving mode and it will respond to your LAN commands via MLGW. No way around it.
