Anyone else having problems posting from an iPad?
I've made 5 replies to posts over the last 2 days and they just disappear into the ether!  No reply is posted on a thread so where do they go?  It's very frustrating as normally I have no problems using my iPad for posting.
Dave.
Yip.... Same issue🙁
iOS 8.4.1 safari and os x 8.0.8 can not edit post on beoworld. You have to open chrome for this. Also sending post is slow so you many times find yourself pressing post a second time and - double post is your game.
Beoworld pull- down menus don't work with Safari on the iPad, nor do smileys, and links are impossible other than posting web addresses in full. Otherwise, iPad still manages to post (if this post appears!)
Graham
Safari for Mac has the same issue, can't open the menu on a post to edit it.
I can normally post and edit via my iPad but recently when I hit the 'post' button, nothing happens and my reply is simply lost and I have to redo it or use my PC. Otherwise it normally works fine. It's only been over the last few days. No problems with speed when it does work or with duplicate posts.
Dave.
Dave.
Hi Dave,
I have the same issue, but from the beginning of using my IPad for posting. Therefore I copy my post before I hit the 'post' button. This way I can create my post easy without typing again.
Regards
Räuber
I am happy, that Safari is no b&o software. The shitstorm would be...........
On my iDevices For Beoworld I don't use a browser -- just Philippe's Beoworld App.
I highly recommend it for its ease of use and ability to add images without fuss.
Yes posts do get lost -- but that happens when my wifi and/or Internet are slow.
Or more rarely the Beoworld server.
And posting on a moving train flipping between 3G and 4G towers is fraught with danger, but browsing is fine.
Beoworld by Philippe ROBIN
https://appsto.re/au/IISVx.i
Same app that I use.
Dave.
