Hi guys, thanks for the input!
It´s a pity that the speaker fret don't to more change to the overall design of the TV. Like on the BS2500 where the covers made a very big difference, or the MX-series with their back casing in different colors. For the price they charge for the fret you get very little back it seems.
I think it could be possible to replace the fabric yourself but the problem is probably to get the right kind of fabric. It has to be very thin to fit inside the box on the steel plate and also be "airy" enough for the speakers to sound as good as possible.
I would like a blue cover for example, perhaps it could even be possible just to paint it with spray paint, not sure I wan't to try it out however =)
Sorry to hear that you can´t see much of a difference hitolaus but I hope it makes a bit of difference at least.
Jonathan, yes I am using it as a standalone unit. It works very good at that. I use it for airplay a bit and I have been enjoying iTunes Festival a few nights this month on the V1 with great sound and video. I do think the matte screen looks a bit dated, watching video on my main tv with a glossy screen or even on my iPad, Mac or iPhone feels different with a feeling of more color and contrast compared to the matte screen.
One strange thing I have noticed is that when I play video from USB that the Natural motion-engine of the TV works much better than on DVB-C. It looks just as on my Avant, very smooth and very nice. I do think there is a big difference and perhaps it is shut of on the DVB-receiver? No way to configure it manually from what I have found.
I have had a few questions and problems which I have talked with B&O about. They have also confirmed that the TV is made in China, but I had to send a few mails to get that confirmed. However to their quality specifications and such. More or less the tv is working fine but is going to be replaced because of the paint chipping issue and that sometimes on DVB-C that my screen goes green (which I think is software but B&O wanted to replace) - and I want to wait until they have been producing it a few months so I can get a tv that is made with perhaps a few different adjustments(?).
Michael
