Any suggestion as speakers for a small room
Hi, I have a beocenter 5000 and a non Beo TV In a small room (around 9 square meter). Now I am planning to add some speakers to connect the BC5000 and the tv as well. Any recommendations? The space is quite limited and maybe panel or otherwise small speakers preferred. I had thought maybe Beolab 4000 or some smaller from RL series..
Beocenter 5000 was made for passive speakers. It won't connect to active speakers without some "adapting".
I would suggest Beovox S45 or S45-2 (type 63xx) or perhaps Beovox 3000/5000 panel speakers.
I always found that CX100  speakers are especially well suited to small rooms.
I love the look of the CX100s and have a couple of pairs myself, but in my opinion they have searing treble and need careful positioning.
Lawrence
Lawrence
Maybe time to recap them. Made a difference on mine.
I don’t doubt that mine need recapping, but the new ones I auditioned at B&O Coulsdon (yes, a long time ago) sounded shrill. I was horrified, but ended up collecting a couple pairs in different finishes purely for the looks.
They sound ok off-axis, and with a Cona or two (one per channel).
Have CX100s attached to my 5500 system - never shrill - I wonder if they were set up in dealer fashion to sound exciting! However I would echo the S45.2 thought above - fantastic smallish speaker.
The S45.2 are indeed great classics, but definitely bulky compared with the CX's. My office is about the same size as the OP (9 sqm) and I sure would not be able to fit them in here.
Thank you for your kind replies. Regrettably BV45-2 are too big for this purpose. I have thought maybe I could install some smaller speakers from Bv C(x) series quite close each other (as sort of soundbar-like) as I want to use the speakers with the tv as well and as the space is quite tricky, I most likely must install speakers under the tv side by side. There's no room for a speaker on the right Side of the tv (corner and door).
