Hi Jesper
My replacement box also said MK IV, but the panel inside was correctly the 200hz MK V panel. So I dont think you have to worry about that. after installation, tjek in the customer menu for 200Hz paneloutput.
Be VERY aware of white spots in dark scenes, (try watching it in a dark room when starting up DTV (with the Bang & Olufsen text) in the lower right corner. Mine has massive white spots even after two 200hz panel replacements, so i guess that is just the way it is supposed to be with the new 200 hz panel(???). My dealer has promised to call B&O and ask them if this is a fault or as it is supposed to be. If I had the oppotunity to choose differently, i would rather have my MK IV panel again and live with the 100hz and humming noise. What i got now is WAY Worse!!!!! SO this UPGRADE(!) is for me NOT an upgrade, sadly :-(
If i was you, i would mention it before they do the switch, that way you can always have them switch it back again!!
AND, if you do not experience the white spots, please keep me informed. Then it might be easier for me to get yet another another another another replacement ...
/Ehlerz
