Another new headphone: BeoPlay HX
matteventu wrote:
Damn.  That's one of the reasons why i didn't buy the H95 and I was looking forward to the HX(10) , so no HX for me
When i read the spec guide and it said
Inputs/Outputs "1.25 m audio cable with 3.5mm mini-jack for corded Connectivity", i was hoping this meant YES to PASSIVE MODE.
lawrencejmcook wrote:
It’s a shame that they’ve put a non-replaceable battery into this new headphone (as they did with H95). Especially after the emphasis they put on the replaceable battery of the Level.
Wow, I didn't saw that! That's a shame, and considering how the design has not evolved from the H9 and the battery is still rated at the same capacity, they put energy just to make it different with a non-replaceable battery. I was considering an upgrade, not anymore.
I would like to see how these compare to the H95.
Any pair of headphones without passive mode capability is a total no go for me. So I will stay absolutely happy with my H7s which sound great as I don’t give a damn about ANC. Sorry B&O you once again take the wrong turn.
But you can replace the battery, takes 2-5 mins with a small screwdriver.
Hello!
We have spoken on Reddit about this (battery availability for the H9 3rd Gen) 😁
Do you know if the HX allow the same easy opening as H9 3rd Gen do?
Send a link to the thread pls, how to open them?
Please sent us a proof, can’t find any info about this. I only see your messages at the Reddit and other beoworld threads.
Can you please be more specific?
What is it that you're after?
I don’t have one here, i asked my dealer and he says it takes him 2 minutes. Take the right earcup off and it should exposed the screws. Detach the battery and reverse order assemble and that’s it basically.
