For those of you not enamoured with the Beosound 8, B&O are releasing the iPort which is made by Sonance. This small device allows your iPod or iPhone to be controlled using your Beo4 and on screen displays anywhere in the house. (You clearly need the linked TV to be in view!) It uses PUC software to control the device. Maybe useful for a second home so you can use the iPod as a mini server.
Hi
I have major difficulties finding a point with this. In my world it would be interesting if iPhone/Pod/Pad could control B&O equipment. This sounds like the opposite. I try to use Beo4 as little as possible. It is no good remote, you can not see graphically what you are doing, bad user Interface, no two way e t c. It is good looking and has good buttons though, but is just a tool.
If B&O could instead deliver something to control beo4 via iPhone, like a very light Master Link Gateway, would be very nice thank you.
Have a nice day
Clakke
