Annoying "Crack" noice from the Beovision 10-40 cabinet?
I experience a quite annoying sporadic noise that probably comes from the cabinet.
It´s easily described as a "small plastic sounding crack noice", similar that I recall one could hear from the plastic cabinet movements when the old CRT TV:s got warm.
It sometimes appear quite soon after switching on the set, and sometimes after like 45 minutes of operation. Once it appear, it "cracks" now and then during e.g. a TV evening.
It´s clearly not from the loudspeaker and its sounds like the cabinets "moves" after its being warmed up.
Has any other BV10 owner experienced this, or are your sets completely silent (apart form the fan)?
/Claes
I had a similar issue with a BeoSound 1.
I took it back and requested a refund. It's not what you expect from a quality brand.
Anyone else have these types of sounds from the BV10?
Yes, mine did that. Not a huge deal - I agree sounds like something expanding. Mine was on a floor stand.
My wall mounted BV4-50 "cracks" quite frequently. I would also agree the cause to be expansion/contraction
of cabinet.
There's a solution for the "cracking" on BV 4 and BV 10, just ask to your dealer 😕
I get it occasionally on my beovision 4, 50" too :((
Hiort
I own 2 versions of BeoVision 7-40 " first Mk II and now Mk. III and
never the "cracking" problem. YOU should have bought the flagship.
B&O factory in Czech "Koprivnice" haven't good Danish glue. ;-)
Peter Pan wrote:
Hiort
Just talked to my local dealer, and it is a known issue, i also experience it with my BV4-50", and there is some strips/tape thingy available to the delaers as fix, and i have just told my dealer to get it and install it in my tv, and it is all payed for by B&O :)
Contact you dealer, it is unacceptable with that cracking noise.
/Weebyx
