The external IR eye is used when you have it connected to a standalone system such as a Beosound with an Aux port, or you only require control of those additional sources in the room you are in. Which as you are using it with analogue sources is fine as you probably start them off in the room with the beomaster in.
I seem to recall I wired it into the lintronic converter which in its turn was wired into a Beolink Converter and became a fake Beomaster.
It worked really well but I replaced it with a Media Streamer controlled by the lintronic box, the media streamer has an analogue input so I use that for my turntable.
