Am I wrong to buy a beosound 35 , use it as a soundbar ?
Hello ,
after deep considerations , i am going to give up my 1st gen beovision 7 32 and go for a Sony 4K 49" oled tv and I just want to buy a beosound 35 as a Soundbar and simple hi-fi for playing AAC files .
Nevertheless , every single review in the universe is complaining that the bs 35 is lack of bass and cannot apply the hdmi arc function while connecting non b&o tvs . Of course I understand that it is not only a sound bar and was not made for that single function .
Is there anybody who is in my situation , have similar experience and can give me some advise ? Please help .
regards
d.
I think there are products far better suited to you out there. I've heard the 35, and it's nice but no better than my Beolit 15 really.
Yes . My biggest fear is the new 35 will not sound as good as my ole Beolab  7.1 . Friends recommend Harman kardon sabre ab 35 which looks good but I am completely ignorance to soundbars.
Why dont you keep the 7.1? You can get it functioning quite easy with the tv.
@godotz
Before you disconnect your BV7-32....
If it has the BL7-1, throw in your favorite CD in the DVD player, turn up the volume a bit, and listen... 🙂
That speaker is not even close to retirement!
And with the Connection Hub it will work just fine  with your new TV!
Thank you guys for advise . Can I hook the beolab 7.1 to a non b&o tv ? I do not know the connection hub thing . I can buy that from b&o stores ?
Agree - use your 7-1 with a Connection Hub.
At least so you have a bit B&O left in your setup.
The BS35 was not intended for use as a soundbar.
This hub was made initially for the S8-speaker set,
but can be used with (almost) any BL.
http://www.beoplay.com/landingpages/accessories/s8
Another suggestion would be to use the Analog-in of the BS Essence/BS Essence (2nd gen)...
...assuming that your new tv has an analog line-level output.
Will go to check . Thank you guys .
Regarding the sound quality of the BS35. Make sure to have a listen since the last update a few weeks ago. Alot have changed. Much better bass capabilities and overall higher volume.
Does a great job a doubling as both soundbar and all-in-one music system.
