Aluminum polish ?
I've just purchased a Beocenter 7700 and I'd like to clean it up. Is there something I can use to clean and polish the brushed aluminum on the top ? Any other cleaning suggestions also. I'm in the U.S. so it has to be something I can get here and would a Dremel polishing kit be safe to use ?
I have been using iKlear Apple Polish for some time now on my beolabs and beosound, plus all the Ipods I have owned with a stainless steel polished back. No problem, worked like a charm.
I'm just cleaning up a pair of Beovox aluminium cased speakers and use Autosol - superb. Ebay has loads of it and cheap too.
Do be careful with anodised surfaces! Abrasives will simply get you to plain aluminium and that will not be the same at all!
