Hi everyone,
I would like to know if it is possible to control a beocenter 9500 from an universal IR controller for instance ?
Thank you.
Hi everyone,
Thank you.
There are a few universal remotes out there that have can handle B&O IR. When you talk about BeoLink are you referring simply to IR control or to audio distribution?
He is probably referring to the "brilliantly" named iPhone app or the Beolink 1000/5000/7000 remote...
I was referring to the remote actually :)
Check out the harmony remotes by Logitech. At least some of them can control B&O. There are other threads on this topic too.
Actually I wanted to be sure that the harmony could control a BC9500 before investing in it actually.
Thanks for all.
Guillaume
It will... but you may have to massage the config to get exactly what you want.
