All you have to connect is the pre outs? Thats it? Does the signal and volume control go through the same wire? I have always wanted to know how a non B&O reciever and Labs connect. That seems too simpleπ€
No volume control at all. When you connect to the line input on the Beolabs, they are basically blasting at full volume all the time - you control the volume with what you feed to them. That is why you need a preamp with controlled volume outputs.
There may be issues with ground loops if/when the Beolabs get their power from a different mains socket than the amp. This might cause a mains hum that prevents the speakers from turning off.
I always thought that a pre-out carried a simple line out signal...? So if the pre-outs do not carry the volume control, what does that? And to try and further understand - what is the difference between pre-outs and volume controlled outputs?
I hope this is also helping those who originally asked!π
