At the moment I‘m not happy with my Beosystem 3. We all know that the Beolab 2 won‘t be turned on in case you have Beolab 5 attached to the BS3. I want to use my Beolab 2 to compensate some room modes.
Does somebody is using the Almando and can tell me if it allows the BL2 to play even when the BL5 are on?
I still don’t get why B&O thought this was a great idea back then..
Btw:
Yes I know that you can plug it in and tell the BS3 that it is not a Subwoofer. But that way you still can’t use it in Speaker Mode 2.
