I'm hoping someone can help me with this because I am incredibly frustrated.
I have new CenturyLink service with Plume Mesh routers and I'm unable to use AirPlay 2 to my B&O speakers (BS Essence Mk2, BS1, A9, etc.). They are all on 5Ghz with strong signal (I am unable set them to 2.4Ghz due to counter app now allowing that configuration). I select the AirPlay to play, it turns on the B&O speakers (nothing plays) then within 5 seconds it completely disconnects. Try again, same thing. Once in a blue moon it will play one song then it completely disconnects. I've tried from both iPhone and iPad with same results. Only device that works is the Apple TV to B&O speakers and it cuts in and out. Using Bluetooth is rock solid, but I really want to use AirPlay for quality and ease of use.
Is there a setting on the router to prioritize AirPlay or a setting on the Essence? All these devices worked great on other routers.
