Hello all, would appreciate any advice
I am looking to buy a BV7-32 with BL7.1 but have come across the issue that the speaker is too wide for the space that I was planning to fit the tv into. Plus this can’t be changed as on one side it’s the outside wall and the other the chimney structure. Bringing it forward so that it would fit would encroach too much into the room.
I was wondering if it’s madness to consider using a pair of beolab 4 instead of the BL7.1
The Beolab 4 placement could be directly above or below the screen at either end so that at least the sound is coming from the same place as the picture.
I have thin walls and am trying to keep on the good terms with the neighbours so, as mentioned, the sound level is never that loud. For example, my current BC6-26 is never above “45” which is loud enough to fill the room with tv sound or music (i can't see anywhere info that shows the power of those speakers).
Plus I have no plans for surround sound etc – not for necessary for my viewing and music choices.
So is it possible / madness to link the beolab 4s as the main speakers?
(PS beolab 3 maybe a long term option but cost is an issue right now)
Many thanks
cjfc
