advice - Penta's as TV speakers on BeoVision 7
Hi All,
Need a little advice on setting up please:
I have a Beomaster 7000 and BeoVision 7 32 MK5 and I want to use the Penta III's from my music system as part of the surround system but still be the music systems main speakers.
The rears are BeoLab 4's and I have at my disposal a 1611 convertor if needed.
Ideas on the best way to hook up and access please?
What units do you have on your 7000 setup?
BeoMaster, BeoCord, BeoGram and BeoGram CD...
All speakers to BV, Beomaster via 1611 to BV.
Ralf
PS: Search for Masterlink Handbook PDF online. Lots of details!
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
See /forum/general-discussion-and-questions/i-like-my-new-h3s#post-1997779
Paul
You will notice a change in sound from the units on the Beomaster when connecting the speakers to the tv.
But for surround setup, it is the only proper way.
many thanks leo
would I connect the Penta's into the TV and make the TV the master (or if I'm going to loose Penta quality playing music should I opt using different front speakers)
I was wondering if anyone else had noticed!
I am slowly working on integrating a BeoCenter 2300 with my BV10 and noticed my BL8000s sounded very different when connected to the BV10 compared to when I was listening to music through the BC2300 with the BL8000s connected directly.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
I forgot one option.
Use a powerlink to rca from the BV yo the Pentas.
And a powerlink from the 7000 to the Pentas.
Just flick the switches when you change source. 😁
I'm liking this idea
