adjusting beovision LX screen geometry
 i've just purchased a BV-LX-2502 and its a great machine, still looking good after nearly 20 years
But after the move the screen has a grey line at the top of the screen which i assume is a problem with screen geometry. Can anyone tell me how to adjust the screen geometry to solve this.
thanks
peter
Clean the glass inside, it's probably dust 😁
Peter,
When you say you now have a grey line at the top of the screen, the following questions come to mind:-
  1. Prior to the move of the TV did this grey line exist ?
  2. When  you say "Grey line" are you talking about a line like a raster line or is it wider ?
  3. Is this line at an angle say 10 degrees ?
Depending on your answers it is likely that the scanning coils have moved on the neck of the tube during your move which is not that uncommon. It only has to move a few mm to have an effect on the picture.
the line is about 4mm wide and it might be at a very very slight angle its a bit hard to say. It wasn't there when i first turned the screen on at home but then on the third time i turned it on the line appeared
There are several presets to adjust the picture geometry,but they become intermittant with age,and cause these sort of problems.It would be best to get them replaced by a competant Engineer,who can then set up the geometry accordingly for you.Don't explore inside yourself,it can be lethal in there,for the inexperienced!!
