Adding auxiliary sources.
Think you have to move your Beoport to the Appel, or run a cable from Apple to the AVANT to connect it like you have today.
Hi, neither of these are viable options.  The distances are far too great.
Has anybody done any research into the old BeoLink PC Office. It used a BeoLink PC Cable Box which had an unused "sound in" connection.  This box then connected to a BeoLink Active.  I have 4 BeoLink actives and three of them have 2 PowerLink din connectors and the other has one PowerLink and one PC din connector.  Presumably this must mean that there is a route into the ML on the BeoLink active with the PC din connector.  Does anyone have one of these old devices and can confirm or deny that this route is a possibility.
PAJ:
I've tried to use this PC din connection but with no success at all 😕 I couldn't find the way to activate this plug using the only beo4, I suspect this PC input needs an external computer software to be activated (maybe the old PC Office windows software?)
so if someone knows exactly how this "PC plug" works, I'm really interested too.
Thanks.
Regards.
Thanks Santiago.  I agree entirely.  If we can find a way to activate this unused input into ML then the possibilities are endless.  Perhaps Keith Saunders may be able to help?
