Adding auxiliary sources.
Not sure how much you're looking to spend, but a BeoSystem 3 sounds like your best option!
Until I got a PC2/Beoport I had the same problem. How to connect a lead from my PC and my Turntable to my BS3000. What I did was get a CD/Tape adaptor. This was a small black box made by B&O. It has a Din connection which will go tou your BS9000. There is a DIN connection in for the Tape connection and RCA connections for the CD. To change sources you just press a button on the front of the box. It is that simple. Infact as I no longer use mine I would be willing to sell it.
Craig🙂
Not a fan of wireless myself either, far too unreliable. So you want to add the audio from your Apple TV onto your Masterlink network. What Masterlink product will be in the room with the Apple TV?
Craig🙂
Nothing! When I remove the Avant then I need to find another "cute" solution ...... if it exists (and it looks as though it doesn't).
What about moving the BS9000 to replace where the Avant was. Then use the Masterlink connection that was for the Avant for the BS9000.
Craig🙂
