Hi All -
I have an all B&O set-up, which despite being all B&O is somewhat unconventional (because it's the only way the dealer/I could figure out to set it up - will explain below).
I'd now like to add a subwoofer (either a beolab 2 or 19) to the set-up but whenever I speak to dealers about this they appear confused and usually give me conflicting advice (not great as it's all B&O stuff so should, in theory, all work perfectly together).
So here's the current set-up:
- I have a Beosound essence (which I use daily for music)
- a Beovision 11 (which is connected to the essence via the essence's line-in - as this seemed to be the only way to be able to use the speakers with the essence independently of the TV and have TV sound going through them too).
- A pair of beolab 12.2s connected to the essence
- A pair of beolab 3s daisy chained from one of the 12.2s.
(in addition, I already have one issue with this current set-up where the final speaker in the chain often stops playing sound and goes to a low buzz until it's turned off and on again or I fiddle with any one of the wires between it and the 12.s it's daisy chained to - but we can leave this issue for another day :)
So, How would I best connect a sub to this set-up? (so that it can work well with both the essence on its own, and with the essence + beovision 11 when that's turned on too).
The easiest way to connect the sub would be to daisy chain it from on the of the 12-2s, but I understand this would either create some sort of delay in bass or wouldn't tell the other speakers that the sub was there, and therefore they would still try to handle the low notes themselves(?).
Any advice gratefully received!
Many thanks in advance,
Gareth.
