I've never auditioned the BL11, and have no opinion of it. However, it will not solve the problem I discussed. 2 drivers (as a general rule) do not have enough bandwidth to cover the 10 octaves of the audio spectrum (say, 20 Hz. to 20,000 Hz.). A good, well-implemented driver might cover 2.5 octaves in a reasonable way. So, 2-way speakers (including the BL3, which actually is a bit more than a 2-way) have serious limitations.
The brilliance of the BeoLab 3 lies in exending the low frequency response of the woofer through using passive side radiators with a different resonance than the driven front-firing woofer, thereby teasing almost an extra octave out of a tiny design. I wish I'd thought of that!
This brings up two related questions:
- It seems like the shape of the Beolab 11 make it almost like a vertical acoustic lens- does it not such a dispersment issue as an ALT since the frequencies are so low?
- There are remarks made about the Beolab 2 being "slow" for bass because of the passive side radiators- if this really an issue, wouldn't it also be a problem with the BL3's? Here is a very positive comment about passive side radiators, but most comments related to the BL2 seem negative.
