Hi folks I am swapping a Panasonic Blu ray player with a Playstation on my BV10. I do not seem to have a list of boxes under the Connections menu, just the one Panasonic Blu ray box that I am currently using. The tv was set up for me by the dealer and this included connecting the blu ray player. Is it likely that the dealer simply installed one PUC code rather than the long list I had on my BV3? Or is there some way of seeing the list of boxes so that I can select the PS3 box? Many thanks for any words of wisdom! C
Access to PUC menu
I think the dealer deleted everything else... Happened to me before... Not very nice but this way you stay in touch ;-)Be aware you need some ps3 to b&o converter, re-bl??!Search the Forum and you will know...Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Keith gave a good explanation in
Thanks guys, very helpful.
Have a great 2012.
C
