Quick question, as in the title . Does the A9 Keyring switch the lights off if they're Lutron as operated by the Beo4?
A9 Keyring ; Lutron compatible ?
it should work with the B&O version of the Lutron devices
Any idea where to buy lutron B&O Rania Dimmers? I'm from Austria and have trief to get in contact with Austrian and German Dealers but no response at all! Its incredible!!!
best Regards Elmar
Sounds promising as we have the B&O version. That works with Beo4.
best Regards Elmar
I looked on the Lutron website . These were listed for Austria;
| EGGER LICHT GMBH | |||
| OBERE TRIEBELGASSE 7 | |||
| FELDKIRCHEN, 9560 | |||
| 004342765507 | |||
| JOSEF NOPP KG | |||
| PASCHINGER STR. 111 | |||
| LEONDING, 4060 | |||
| +43(0)73268004067 | |||
| www.nopp.at | |||
Thanks for your help:
Egger Licht - got an answer but no help at all
Nopp KG does not sell Lutron any more
Also contacted Megscon - but no response...
No help at all; Stb Brackets also sell Lutron; but I would need some help concerning installation...
Best regards Elmar
Nopp KG does not sell Lutron any moreAlso contacted Megscon - but no response...
Best regards Elmar
If you're going to get Rania wall switches the installation is simple enough for any electrician . I bought from Stb and used our usual guy for the job.
The A9 keyring arrived today. And it works fine with the Rania!
knowing the power of the Beo4, it may even have enough IR from outside in the front garden when we get home?
