A8s - are they easy to repair?
Would it be cheaper to buy new A8's than repair them? Of course, that would depend on what needs fixing exactly, and how much skill and time the technician would need to use. Besides, how much is your time worth, which brings me back to: would it be cheaper to buy new A8's then to repair an out of warranty unit?
-Sal
In the Serenata thread Alex mentioned this:
"You have to get new A8s with the modified plug so the fit."
This was in reference to the plug not fitting in the recessed headphone port of the iPhone.. My current A8s have a plug that's too big to fit.
Have the A8s been updated since 2002 when I bought my pair? If so, do they have an updated plug and, hopefully, a more flexible resilient wire.
Anyone bought a new pair recently that can see a diffrerence?
Well, £35 for parts and labour which is definitely better than £95 for a new pair I suppose - but 14 days without my A8s! I had thought I'd make do with the stock ipod earbuds in the meantime but I just had a listen and I'd forgotten how horrendous they were. At least i've got my Sony Eggos - a bit bulky but they sound good.
I would like to know how easy the A8's are the take apart at the earphones, as I am intending on replacing the cable with the iPhone mic cable. I have already done this with my Etymotics in preparation but that was a much easier task.
Nicholas
