A2 or Beolit 15
Id go the A2 if i were you, you can chuck it around and if you're on the grass it can lay on its side etc and is easier to place wherever.
Go take a listen and see which one you prefer.
The BL15 works better if its placed down low and against a wall in a room if listening inside.
Not agree Michael. πThe Beolit 15 have the 360 sound space technology. It sounds better in the middle of a room. Against a wall the bass is too loud.You description concern the Beolit 12. π Login to view imageThe BL15 works better if its placed down low and against a wall in a room if listening inside.
I went for A2, and happy with that. The sound is amazing and a good bass concidering the thin layout. Sometimes I feel a Beolit 15 would have been great to have, but the A2 is more versatile and handy to bring along.
I faced the same dilemma, same issues. Liked the colors and portability/weight of the A2, and it did sound great. But (there's always a but right?), one place I wanted to use it was out by the hot tub, and with the pump and jets and being outside the ability to play louder and deeper was important, more so than throw it in a beach bag portability so it was the Beolit 15 that won out.
Really enjoy it though, but I don't think one could go wrong with either.
My wife takes her A2 black and copper everywhere. She really really enjoys it, and it continues to surprise me with how much punch it has.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
