A1s in stereo pair - Fantastic!
Obviously, many of us have found the A1 to be a wonderful portable speaker.  Having owned the BL 12, A2 and auditioned the BL15 on more than one occasion, I can say that the A1's combined feature set make it the hands down best choice for me for portable use.  Shortly after getting my first, I was curious about how 2 would sound as a stereo pair.  In short, I'm absolutely thrilled.
If you keep in mind reasonable limitations about the creation of a soundstage and stereo image from 2 small speakers laying flat, I think most people would be very happy with what they can do in stereo.  It's obviously better if you can hang them from a hook, but they do surprisingly well just sitting on a desktop.  The bluetooth stereo pairing is a little glitchy at times, but once you figure it out, it works.  Dropouts can occur if you move either speaker or the source device (this I have decided is more related to the challenges inherent in doing stereo pairing over BT - I've seen it with BT speakers from other manufacturers that offer stereo pairing with 2 units).  In a worst case, you could go wired - 3.5mm stereo to mono breakout splitter with a cable then running to each speaker.
I've already taken these on a trip and have decided that they will be my go to travel speaker solution.  Now I just need a good dual unit travel case solution.  😁
After hearing the fantastic performance of a single A1 I thought I had to get one for the stereo experience.
Just this morning I started to play with it for the first time. I got the two speakers to pair. The easiest way is to follow the instructions on the B&O Faq page and not use the App. It may be my phone but the app seems a bit flaky at times and I've seen complaints about recent updates causing problems.
Anyway, using my phone to play music via BT, the sound is really good. So much better than just one.
The problem I have is that I have all my music on a non-BT ipod so I need to connect via the 3.5mm line in. Did you find a way to do that at all? The splitter option might work if I can find one but I'd rather use the technology if possible.
I was always told that the A1 couldn't be setup in stereo - even my local dealer confirmed this. He claimed just the A2!
Do you mean it can't be paired with the line in or at all?
It definitely works with Bluetooth. There are issues but when your phone isn't stalling or whatever causes the very occasional drop out, it's very good.
Now the line in, that's what I want to use and I'm sure I saw something say it was possible back in late December. Can't find it now though.
Not true Moxxey
I have 2 A1 and have done the stereo.
Today I gave one A1 to my dad and he goes "how does it work without wires" haha.
But yes, it definitely works in stereo.
The Beolit 15 also, not just the A2.
Dealers generally seem to know very little. Even those that are official B&O.
Sad development.
So can I pair a Beloit 15, and and A1?
You'd probably get a BeoMule, then ;-)
I still haven't worked or found out how to pair with the line in but I can confirm that if I hook up one speaker with the USB cable I can feed my laptop output from iTunes to it and then pair it to the second speaker with lovely stereo results.
Karl
