A-APPLE in Beo4 List?
Try using it while your active source is either the analogue input, web media or home media.  It *might* work.
'try using it...' - using what?
The command that you're asking about?  AV and P-AND-P will only work with certain input combinations on V1/V11/BS4.  Basically they will only work with an HDMI source and an internal or analog source simultaneously from what I understand.
NVM just tested it ... only works with P-AND-P not AV.
Hey,
having a V1 now, I really was looking forward to use it the way Millemissen wants to use it.
So hopefully we find a solution.
This thread has been looked at nearly 500 times.
Would be nice at least to know if other V1/BV11/12NG-users (other than I and Lenny) miss this function too.
Might put some pressure on the guys in Struer, if I could write them that support for the AV-function is a thing that they must bring in the next update 👍
