Yesterday I bought a Beocenter 7002 and I have some questions.
Anyone any idea what this 8 pin din connector is for?
The casetteplayer isn't running. What is the common failure?
thanks,
Hans
thanks,
Hans
The cassettedeck will need new belts and idler wheel rubber parts. That's very common.
I can supply both.
If the motor isn't running, check the voltage supply to it.
A good cleaning and lubricating of the mechanicals would also be good.
The 8 pin DIn is an add on - you will probably find it plugs in the back somewhere and has been done so you don't have to pull the Beocenter out every time - ? for a working cassette or maybe an MP3 player?
It comes out of the Beocenter next to the power cable, at the back are no connections.
guess I have to open it to see where it goes.
If all eight pins(or recepticals rather)are in place,my guess would be this an adaption for powerlink active speakers?Only one socket as the 'speakers can be daisy chained of course
I've been asked to this on occasion with vintage B&O kit where the owners wanted to use modern active B&O speakers like Beolab 6000/8000.
Works well and the nice integral amplifier can still be used to drive passives in another room say,controlled by the 'speaker switches.
Nick
Heres is the place the 8 pin is mounted.
So is it for a subwoofer?
I also found the problem with the casette player.
So ordered new ones.
Bad pics.
I'll try again:
So the white tape is the connection of the 8-pin
depending upon exactly where the cable is connected,it does seem to be an output rather than an input?
IC2 in your photo is the first stage of the volume control,before the tone controls,where the output would be "flat" without bass or treble boost,so ok fo r say a recorder connection,but prap's not for powerlink or bass bin?
Another clue will be revealed if you open the din connection to see which pins are used?
If the connection is for powerlink,there should be a wire connected to pin 1 to trigger the speaker also.
Nick
It may be the DIN input for a CD player as part of kit 8002248 – at least that’s what is is on my Beocenter 7002.
