...remember to press exit when you are done..🙂
And dont change ANYTHING in the service menu. If you do; a technician probably has to come by and correct it.
GL
GL
This is great info, thanks Stefan.
Here's the info I got :
06 IC3 AP SW04.24a
06 IC2 IOP SW23.00a
And the errors :
TV1012 34-2E
TV 0930 34-2E
TV 0919 34-2E
TV 0914 34-2E
TV 0905 34-2E
ML TD
Do you think it's bad ?
I'll stop by my dealer later today. Hopefully he knows about this...
Olivier
As a lot of people know on here, my BV7-40 MKIII and now the MKIV both crash when using a Sky HD box connected to the BV7-40 and BV8, at the same time. It's never gone away! The BV7-40 MKIV crashes and eventually turns off - it's not the Sky box, either, as you can continue to control and use the box, through the BV7, connected to the BV8!
It only crashes when watching Sky. DTV, DVD and other sources are fine.
According to my dealer it is a known issue and other people are affected. Been waiting for a sw fix for weeks now.
06 IC3 AP SW04.24a
06 IC2 IOP SW23.00a
And the errors :
TV1012 34-2E
TV 0930 34-2E
TV 0919 34-2E
TV 0914 34-2E
TV 0905 34-2E
ML TD
Olivier
Sorry, I don`t know much about the error codes, but your dealer should be able to read it via Beo`s Intranet.
And thanks to BMGHB for the advice I forgot: Don`t mess around in the service menu....
Stefan
The BO technician just updated the software of my BV7-40 MK3 to the latest version. We'll see if it helps -- it'll take a few days/weeks to figure it out.
