5 1 setup
How to connect BL8000 + BL6000 + BL4000 + BL2 + BC2 to Pioneer TV?
BS1/BS2/BS3 🙂
third-party amp with pre-outs
Like this one - you'll only be using the pre-outs, but you can set levels from the receiver, and you'll get an excellent 7.1 sound, while you can connect whatever sources you have through the INs.
linkg
So cool. Excuse my ignorance but how will you connect the powerlink cables on it? With cables form Soundsheavenly let's say??
using phono/rca sockets and the line-in inputs
The speakers should work, but will the BL2?
And presumably the speakers will need to be manually turned on, unlike a Beosystem solution?
Justin
