4K video options?
I changed from 2 BeoSystem 3 to 4. Better Sound. But will use HDMI spitters + Lintronic to use 4K in the Future.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I have found the simplest solution is just an AV receiver.
Almost all have all the wireless streaming for music, connectivity to your smart phone, multiple sources, all with one simple HDMI connection to the tv.
Proper Dolby or DTS surround decoding, built is high quality DACs. For video, they all have full 4K and HDRI throughput.
One box, one TV, one remote, multiple sources. Multi-room capability.
All it needs to have is preouts. Yamaha, Denon, Marantz, Pioneer, all make exactly what you need.
The multi-box thing, I feel is a thing of the past.
I’m running 9.2.2 channels with all B&O speakers, and an OLED 4K TV.
I also have a Beosound 9000 as a source for my CDs. I am planning on adding a Beogram 8002 for Vinyl. So you can still incorporate a nice Beogram or Beosound.
If my issues with my avant continue after it is being fixed, then i will use my Sony A1 OLED with an axxim / axiim q box and some beolabs.  It also has one remote in that regard too
Question i have is there any sync issues with the sound?  Also which BL's are you using for which channels?  Are they always on (green), or do they switch in stand by ? do any of them turn off whilst you are watching something?  just out of curiosity.
Thank you
Just use any 4K source (apple tv,google chromecast ultra etc) and hdmi splitter.Hdmi from the source into the splitter,one output into the tv for video,another into the Beosystem 3 for audio.
Works fine with my Bsys3 and Google Chromecast Ultra.
