46-inch BeoVision 10-46 coming
Thank you RWST.
That sounds more fair.
Thanks too RWST for the estimated price of the BV10 46".
7500 euros was the price (approximatively) of the former Avant DVD 32".
Cheers,
Guy
I've already upgraded my BV 7-32 to a BV 10-40, thinking a larger screen wouldn't be available within the year. The 46" screen will be more appropriate in my living. I'll try to negociate a change.
Does anyone know the dimensions? I supposed it could be around 1,20 x 1,20 m. Do you also knowif the wall bracket will be the same for both versions?
Cheers, Marc.
Hi Marc,
Concerning the wall bracket, according to my dealer in Zurich, the wall bracket will not be uniform for the BV10-40" and "46.
Dimension wise it is rather difficult to tell the size, although the ratio for both the 40" and 46" is expected to remain the same, so do the math.
Regards
Thanks for your answer. I was hoping for the same wall bracket, which could let me change easier.
Kind regards, Marc.
It wouldn't stop you to buy the 46", would it ;-)
I heard that B&O will officially unveil the BV10-46 in mid-April.
Around 7500EUR is also the price I've heard from a dealer. This will be without the anti-glare screen which will be approx. 940EUR as I understood.
According to a normally quite good source, the retail price in Denmark including a Beo4 and DVBHD will be 54990 DKK excluding the anti-glare and 61995 DKK including the anti-glare coating.
The current price for BV10-40 in Denmark is 43495 and 48995 for the versions without and with the coating.
This indicates a 26% priceincrease over the 40 inch.
Hi Johnnielse,
My official B&O dealer in Zurich confirmed this date as well.
Can't hardly wait!
Regards
