2nd BeoLink Converter NL/ML Setup problem
I thought the same, but then realized it's probably separated rooms with only Ethernet between the two.  Otherwise you are correct only one BLC is needed. Alternatively, a separate BLC per ML product allows you to address each product on the app(s).
Soren wrote:
Is the 10-32 the only Beovision that hasn’t fully supported Masterlink capability? I have a Beovision 1LS (link slave) and when I used it as a master in option 1 some years ago it worked perfect.
Søren
What was it connected to?
Hi, the 2 BVs they are in different rooms. Far away from each other :-)
No ML connection to the other room, just NL / Ethernet.
BV 10 has no NL only ML, the N.MUSIC sources are NL: Beosound 2  and M5 in other rooms (kitchen and bedroom)
I like to use the MLGW, which is in one room connected to NL.
I works fine, but with the little issue above mentioned.
I just have to unplug/replug the Ethernet once and then it works until next day :-)
Ralf
i does not work. i bought a ML-Power Box and setup everything new but the same issue remains. Only rebooting or unplugging the NL cable helps.
I tried again another router, another port, new NL cables, new ML cable (from my working setup) and another NL source for N.Music e.g. Beoplay M3.
My dealer told me, that the BV 10-32 has full ML capabilities, there is no limitation. Isn't the mainboard and the ML module the same as in the BV8-40?
My setup in this room:
The NL/ML Converter is setup as Audio master (A.Option 1)  no Powerlink speakers but ireye connected.
The BV10-32 is connected directly with ML cable to the NL/ML converter
ML Power Box installed.
BV10-32 V.Option 1 (tried 2 as well)
Latest Software on ML/NL Converter and BV.
I found some other interesting inconsistencies:
The Beoapp does not find the second Converter, only the first  one is visible. May be this an Beoapp related issue.
The BeoSetuptool sees the NL/ML Converter, but says it is offline??
All NL products see the NL/Ml Converter in the 'Connect to other devices' or in the search menu.
Pinging the NL/ML Converter from a PC is always sucessful with adequate response times.
Next try is to exchange the two converters, to be sure, that it is correct working.
Any help is welcome.
Ralf
after spending additional several hours of investigation I gave up and made a rearrangement of the Beovisions
I left the configuration in the NL/ML converter untouched. (A-Master, A Option 2)
I exchanged the BV 10-32 with a BV8-40 and the NL/ML Converter ist working now! I could see it in the BeoApp as well and it works perfectly together with M5 and MLGW.
The BV10-32 was installed in a room which has Cat7 ML Cable and set to V.Option 6 and works perfectly in the same way .
After all i think there must be an incompatibility between BV10-32 and NL/ML Converter when a real Audiomaster is missing.
ML PowerBox is not the solution.
Ralf
Well certainly a way to over come the problem.🙂  Sorry to hear the ML power box wouldn't do the trick in the original configuration. The 10-32 was a weird one.
