i have a working BeoLink Converter NL/ML setup with Beovision 10, Beosound 9000.
It is configured as Audio source and delivers N.Music / N.Radio to the Beosound 9000 from a NL Beosound 2. Works since 2 years now like a charm.
I have another Beovision 10 in my hobbyroom and want listen to N.Music / N.Radio as well.
I bought a second BeoLink Converter NL/ML and it is connected to the Beosvison 10 with ML and on NL directly to the router.
It is of course configured as Audiomaster and has an irEye connected just for forwarding the Light and Control commands to my MLGW. I configured N.Music / N.Radio to ML from BeoPlay M5.
From the ML side nothing is shared to NL
It has a static IP address. Beovison has V.Opt 2, BeoLink Converter NL/ML A.Opt 4.
Everything works but just once or twice, the next day I have no sound. (Beovision turns on, BeoLink Converter NL/ML turns on even BeoPlay 5 turns on!) And I cannot send Light / Control Commands to the MLGW, the errror log on the MLGW shows nothing. The Beovison goes off after a while.
I can access the BeoLink Converter NL/ML from a PC without any problem.
In case i unplug the ethernet cable and replug it, it comes back to live, a reboot does it as well.
But this cannot be the solution. What is going wrong?
I changed the port of the router, i changed all cables ML and NL but nothing helps.
I used another Beoplay Source A6, M3 and Beosound 1 but this does not work at all.
Do you have any idea what to test or configure next?
Is it correct to configure both BeoLink Converters with N.Radio / N.Music?
Ralf
