28" Avant Screen Fault
Hello there,
I'm having a problem with my electronic curtain on my 28" Avant 100HZ.
In all formats, other than 16:9, you can see a thin vertical greenish coloured line going all the way down the left side of the edge of the black curtain.
When the image is in 16:9 ration the line does not appear. It only seems to be on the actual curtain.
Does anybody have an idea of how to remove the annoying line?
Welcome to beoworld.
the problem properly lies in your picture tube. it's possible to bay a little time by adjusting the G2 voltsh but it's best to get a technician to do this..
Cheers for the advice.
So do you think the tube is on its way out?
The tube is on its way out for sure, unfortunately quite a common fault on early AVANT's
