2 Serene questions
If phone numbers in the phone are copied to the SIM card, they all appear twice. Is there any way to copy numbers to the SIM card without having duplicate numbers in the phone book?
When my Serene is in the closed position, the two pieces seem a little loose at the hinge. They will move slightly sideways in relation to the other half. When open, all is tight and there is no movement. Is this normal?
Thanks!
Ours is a little loose when closed also, so i guess it is normal. When you copy the numbers it may ask to move or keep original. Select move, otherwise you'll have to go through and delete all of the numbers in the phone memory.
I have the same problem when the phone is closed. A bit loose. Have tried tightening the screws but still the same.
I can not find a "move" function on mine?
copy all numbers to the sim card, and then put in a different sim card and select delete all.
is there anyway to copy numbers to the sim card all at once instead of individually.
very time consuming ;(
