Recommendation homecinema setup : BL8000+BL7.2+BL3+sub vs BL9+BL7.2+BL3
Hello everyone!
I am setting up a Bang & Olufsen home cinema system and I'm debating between two speaker combinations. I’d like to know which one you recommend and why, based on your experience.
<ul class="marker:text-quiet list-disc"> <li class="py-0 my-0 prose-p:pt-0 prose-p:mb-2 prose-p:my-0 [&>p]:pt-0 [&>p]:mb-2 [&>p]:my-0">
Option 1: BeoLab 8000 fronts, BeoLab 7.2 center, BeoLab 3 rears, and BeoLab 2 or BeoLab 19 subwoofer
Option 2: BeoLab 9 fronts, BeoLab 7.2 center, BeoLab 3 rears. No subwoofer included.
All speakers are connected to Beosystem 4 What do you think?   Thanks in advance
2 MM
Thanks! I asked the AI a question and its response was exactly the same, even optionally adding a BL19 for even more a cinematic effect..but i think it is not necessary Chema
Hello Chema, I trust the BL9s are better than the 8000s. But I am not so fond of how they look. So my setup has BL8000, BL7-1 & BL2 with a BeoSystem 3. And I enjoy it every day. Just to make choices harder 😋. Wishing you wisdom, regards, Johan.
I fully agree with you and may be depend of the use … I’m looking a deeper bass for cinema mode, the 8000 are very good speakers but I think they struggle with low frequencies. it is a harder choice! thanks a lot chema
Happy with BL 8000 / 7.2 / 6000 / 19 here. I couldn’t abide the appearance of the BL9 and much more convenient to be able to wall mount the 8000s.
I have a 7.1.4 Dolby Atmos setup with a Beosound Theatre and six black Beolab 9 speakers. The Lab 9 speakers provide a very even bass distribution for a very immersive experience. I find that the low height of the Beolab 9 makes it blend in with the room and become very inconspicuous. Also, the acoustic lens is the ideal height to be ear level when you're sitting to watch a movie.
That must be amazing 😻 MM
<pre id="tw-target-text" class="tw-data-text tw-text-large tw-ta" dir="ltr" tabindex="-1" role="text" data-placeholder="Traducción" data-ved="2ahUKEwjlj-utgtSQAxWgVKQEHYseD60Q3ewLegQIBRAV" aria-label="Texto traducido: Incredible installation!!! Out of curiosity, what function have you assigned to the speakers? Surround, rear, side...?">Incredible installation!!! Out of curiosity, what function have you assigned to the speakers? Surround, rear, side...? thanks a lot! Chema
The Beolab 9 speakers have the roles of front, side surround, and rear. The Beosound Theatre is center channel. Four Beolab 4000 speakers have the height channels and there is a Beolab 2 for the subwoofer. The Beolab 9 speakers and the Beosound Theatre actually have bass low enough to be subwoofers, too.
