HELP! getting headphones “buzz” feedback
Hello, I was hoping someone could help me understand how to resolve this issue. I have a Beocenter 9000 and recently received a connector from Sounds Heavenly, that plugs into the auxiliary DIN port into the back of the in and out connections on my FiiO K9 pro amp. when I pause a song using listening through my headphones, there is a huge “hum/buzz “ sound that only gets worse when I increase the volume on my amp. if I plug directly into the Beocenter headphones jack, there is no feedback sound at all. Also, when listening to music via Bluetooth or with the USB – C connection from the amp to my phone, I get no feedback in the headphones. Is there a different way to connect an amp for headphones to the Beocenter that could reduce this feedback during stopped or paused play? Thank you in advance.
You probably created, or already had and didn't notice, a ground loop. It would be helpful to anyone trying to help you if you could provide a diagram of your system that includes all audio/data connections between components as well as power connections. Glitch
Hi Glitch, Sorry to hear that you are having problems. Please can you try the cable in the Tape 2 socket of the Beocenter instead of the Aux socket? This should resolve the issue in most cases, but please ask if you need any further help. Kind regards, Steve.
