Beosound 9000 + shelf stand - dimension?
The Beosound 9000 is ~ 30cm / 1 ft in height, when stood up in horizontal orientation.  My question: what is the height of the unit when placed horizontally in its shelf stand?  It looks like the shelf stand adds an inch or so at the base…but it also leans the unit backwards by some degrees.  What is the combined height? Thanks!
I needed to know this to fit my BS9000 below my TV. It is 32.5cm - Just a little less than the dimensions on Matador's post. Stoobie
Exeter, Devon, UK
Thank you both.
